I have edge handler selected by user from ProSelect API. This selected edge is in drawing view. I would like to know edge coordinates in terms of drawing sheet origin using pro toolkit.
What XYZ co-ordinate I will get if I will use API something like EdgeXYZEval? Will it be of assembly co-ordinate? If yes, how one can convert it to screen co-ordinate of drawing file?
Let me know if you need more clarification.
Any thought will be of great help on this.
Thanks and Regards
Ketan
Hi all,
Ketan please take a look at the code corrections.
ProAsmcomppath error is due to a part selection , the correct technique is to check for a NULL as an owner of ProAsmcomppath and reinit if this was the case or simply initialize matrix to identity matrix - the results would be the same.
I was not correct suggesting inverting matrix - this suggestion was related to drawing sheet matrix when you'll need to go from 'paper coordinates' to drawing coordinates - not needed in your case.
HIH.
Feliks.
Ketan Lalcheta wrote:
I tried below code snippet:
ProError status = PRO_TK_GENERAL_ERROR;
ProAsmcomppath objCompPath;
status = ProSelectionAsmcomppathGet(objSelection,&objCompPath);
if (status != PRO_TK_NO_ERROR){return status;}
ProModelitem mi = {(ProType)0,0,0};
status = ProSelectionModelitemGet( objSelection, &mi);
if( objCompPath.owner == NULL) {
status = ProAsmcomppathInit( mi.owner, NULL, 0, &objCompPath);
ProMatrix objMatrixCompAsm;
status = ProAsmcomppathTrfGet(&objCompPath,PRO_B_TRUE,objMatrixCompAsm);
ProView objView;
status = ProSelectionViewGet(objSelection,&objView);
if (status != PRO_TK_NO_ERROR){return status;}ProDrawing objDrawing;
status = ProSelectionDrawingGet(objSelection,&objDrawing);
if (status != PRO_TK_NO_ERROR){return status;}ProPoint3d objSelPoint;
status = ProSelectionPoint3dGet(objSelection,objSelPoint);
ProVector objSelPointTemp;
objSelPointTemp[0] = objSelPoint[0];
objSelPointTemp[1] = objSelPoint[1];
objSelPointTemp[2] = objSelPoint[2];ProName objViewName;
status = ProDrawingViewNameGet(objDrawing,objView,objViewName);
if (status != PRO_TK_NO_ERROR){return status;}ProMatrix objMatrixView;
//wrong
//status = ProViewMatrixGet(objDrawing,objView,objMatrixView);
//wrongstatus = ProDrawingViewTrfGet( objDrawing, objView, PRO_B_TRUE, objMatrixView);
//needed if you have drawing coordinates which are 'paper measurements' so to speak
//ProMatrix objMatrixSheet;
//status = ProDrawingSheetTrfGet(..., objMatrixSheet)
//ProMatrix objMatrixView_Inv;
//ProUtilMatrixInvert(objMatrixSheet,objMatrixView_Inv);
//if (status != PRO_TK_NO_ERROR){return status;}ProMatrix objMatrixCompAsm;
if (status != PRO_TK_NO_ERROR){return status;}ProVector objSelPointAfterAsm;
//from component to assembly
status = ProPntTrfEval(objSelPointTemp,objMatrixCompAsm,objSelPointAfterAsm);
//from assembly to drawing
status = ProPntTrfEval(objSelPointAfterAsm,objMatrixView,objLeaderLocationFrmAsm);
if (status != PRO_TK_NO_ERROR){return status;}/***************************************************************************
let me know whether it is correct or not. In addition to that, ProViewMatrixGet API return -1.
THanks and Regards
Ketan
Hello all,
Ketan, here is a workflow:
- from the edge's ProSelection get ProAsmcomppath, ProDrawing and ProView
- get Point3d from ProSelection
- get assembly component path transformation from part to assembly
- get transformation from assembly to drawing view ( don't forget to invert )
- get transformation from drawing view to drawing sheet ( this one is optional)
- multiply transformation matrixes to get the total transformation
- transfer Point3d using the final matrix to view ( drawing) coordinates
HIH.
Feliks.
Thanks Feliks for this information.
Could you please help me from below step no 3 as I could reach till that point and could not find how to proceed further:
1. from the edge's ProSelection get ProAsmcomppath [ProSelectionAsmcomppathGet], ProDrawing [ProSelectionDrawingGet] and Proview[ProSelectionViewGet]
2. get Point3d from ProSelection [ProSelectionPoint3dGet]
3. get assembly component path transformation from part to assembly
4. get transformation from assembly to drawing view ( don't forget to invert )
5. get transformation from drawing view to drawing sheet ( this one is optional)
6. multiply transformation matrixes to get the total transformation
7. transfer Point3d using the final matrix to view ( drawing) coordinates
To conclude, I got 3D point of selection and transformation matrix of 3d point with respect to assembly. Now, I am not sure how to proceed.
Thanks and Regards
Ketan
ProView objView;
ProUtilMatrixInvert(objMatrixView,objMatrixView_Inv);
status = ProPntTrfEval(objSelPointAfterAsm,objMatrixView_Inv,objLeaderLocationFrmAsm);
let me know whether it is correct or not. In addition to that, ProViewMatrixGet API return -1. ![]()
THanks and Regards
Ketan
Hi all,
HIH.
Feliks.
ProView objView;
//wrong
THanks and Regards
Ketan
Thanks a lot Feliks.
It worked. Appreciate your effort to make me understand in detail.
Regards
Ketan
I use this method <ProDrawingViewTransformGet>
,Translate the (0,0,0)point from the 3D model to 2D drawing origin
