Edges of PDF print are still boxed despite config.pro settings
MP_9215870
I sill have boxed edges in PDF prints despite these settings in the config.pro
Why does the settings not work?
Please specify which version of the program you are using.
what command do you use to create PDF ? I think you must use Save As command and select .pdf output format.
Martin Hanák
Yes it worked with "save as" but still not with the print PDF command.
I use Creo 8
I use Creo 8
so ... you have to find a way how to configure the print PDF command. It's just up to you. I can't help you.
Martin Hanák
