Exception at connecting to CREO Session
hamzawaseem
Hi there,
My java application is working perfectly on one computer, but for some reason it isn't working at another workstation.
I have installed the OTK for java and set environment variables properly.
But in my code, I get an exception on connecting to creo,
com.ptc.pfc.Implementation.pfcExceptions$XToolkitCantModify at com.ptc.pfc.pfcAsyncConnection.pfcAsyncConnection.AsyncConnection_Connect(Native Method)
Any idea what might be the problem here?
Hamza
Hamza
@hamzawaseem wrote:
Hi there,
Hamza
please read https://support.ptc.com/appserver/cs/view/solution.jsp?source=Sitecore Article Viewer&art_lang=en&n=CS321596 document.
Martin Hanák
@hamzawaseem @MartinHanak Did you find any resolution to this issue?
I have similar issue while running vbapi application on other user's system.
Any help would be appreciated.
Prasad
remy
(To:Prasad_G)
If the issues have the same root cause then you may well try and update the .NET framework like suggested with this article https://www.ptc.com/en/support/article/cs352808
