Hello everyone,
We use Creo10.0.
I am able to export a DWG but certain parts of the drawing are missing. e.g. the title block.
Does someone know a solution. maybe it is relate to me using CCpfcDWG3DExportInstructions but no other instrutions i tested deliver a openable DWG.
public static string ExportToDwg(string inputFilePath)
if (string.IsNullOrWhiteSpace(inputFilePath))
throw new ArgumentNullException(nameof(inputFilePath), "No input file path provided.");
if (!System.IO.File.Exists(inputFilePath))
throw new ArgumentException($"File path does not exist: {inputFilePath}");
Interop interop = new Interop();
IpfcAsyncConnection connection = interop.Connection;
if (connection == null)
throw new Exception("Invalid Creo connection.");
FileInformation fileInfo = new FileInformation(inputFilePath);
IpfcBaseSession session = interop.Session;
Interop.ClearSessionCache(session);
session.ChangeDirectory(fileInfo.directory);
// Apply DWG Settings
Interop.ApplySettigns(session, "dwgSettings");
try
IpfcModel model = interop.GetModel(inputFilePath);
if (model == null)
throw new Exception("Model could not be retrieved.");
if (model.Type != (int)EpfcModelType.EpfcMDL_DRAWING)
throw new ArgumentException("Given model is not of type Drawing");
// Using Creo API for DWG Export
IpfcDWG3DExportInstructions dwgExportInstructions = new CCpfcDWG3DExportInstructions().Create();
if (File.Exists(fileInfo.exportedDWGFilePath))
File.SetAttributes(fileInfo.exportedDWGFilePath, FileAttributes.Normal);
System.IO.File.Delete(fileInfo.exportedDWGFilePath);
// Export DWG
Logger.Info("Trying to export DWG.");
model.Export(fileInfo.exportedDWGFilePath, (IpfcExportInstructions)dwgExportInstructions);
Logger.Info("DWG Export successfully.");
if (File.Exists(fileInfo.dwgPathForVault))
File.SetAttributes(fileInfo.dwgPathForVault, FileAttributes.Normal);
File.Delete(fileInfo.dwgPathForVault);
System.IO.File.Move(fileInfo.exportedDWGFilePath, fileInfo.dwgPathForVault);
// Ensure DWG file is created
if (!System.IO.File.Exists(fileInfo.dwgPathForVault))
throw new Exception("DWG file was not created. Check Creo log for errors.");
Logger.Info("DWG Export completed successfully.");
connection.Disconnect(5);
return fileInfo.dwgPathForVault;
catch (Exception ex)
try { Interop.ClearSessionCache(session); } catch { }
throw;
}I apply settings to creo like this:
public static void ApplySettigns(IpfcBaseSession session, string settingName)
ConfigReader configReader = new ConfigReader();
Dictionary<string, string> settings = new Dictionary<string, string>();
try
settings = configReader.GetSettings(settingName);
catch (ArgumentException ex)
Logger.Error(ex.Message);
if (settings.Count > 0)
foreach (KeyValuePair<string, string> setting in settings)
try
// configOptionName and configOptionValue
session.SetConfigOption(setting.Key, setting.Value);
Logger.Error($"Could not set {setting.Key} because of: {ex.Message}");
}These are my settings but in the export log they seem not to be applied:
<drawingSettings>
<add key="enable_popup_help" value="no" />
<add key="display_axes" value="no" />
<add key="display_coord_sys" value="no" />
<add key="display_planes" value="no" />
<add key="display_points" value="no" />
<add key="allow_mfg_in_assem_mode" value="yes" />
</drawingSettings>
<dwgSettings>
<!--https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/#page/data_exchange/interface/Controlling_DXF_and_DWG_Export.html-->
<add key="DWG_EXPORT_FORMAT" value="2018" />
<add key="INTF2D_OUT_DXF_MAPPING_FILE" value="C:\PTC\cadpool\Kelvion_NOB\parametric\data\Kelvion_NOB\config\profile_dir\sut_dxf_export.pro" />
<add key="DXF_OUT_DRAWING_SCALE" value="NO" />
<add key="DXF_OUT_SCALE_VIEWS" value="NO" />
<add key="DXF_OUT_SEP_DIM_W_BREAKS" value="NO" />
<add key="INTF2D_OUT_STROKE_TEXT" value="All" />
<add key="INTF2D_OUT_ACAD_SPLINES" value="AS_SPLINE" />
<add key="INTF2D_OUT_ACAD_HATCHES" value="AS_HATCH" />
<add key="INTF_OUT_LAYER" value="NONE" />
<add key="INTF2D_OUT_ACAD_MTEXT" value="YES" />
<add key="INTF2D_OUT_ACAD_UNICODE" value="NO" />
<add key="INTF2D_OUT_ACAD_TEXT_ALIGN" value="AS_IS" />
<add key="INTF2D_OUT_PNT_ENT" value="NO" />
<add key="INTF2D_OUT_OPEN_LOG_WINDOW" value="NO" />
</dwgSettings>I much appreciate your help!
Hi @JW_12611872
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
