Creo 9.0.6.0
Dear PTC team,
I want to figure out how to customize Ribbon via Creo TOOLKIT. To do it I launch an example from Creo 9.0.6.0\Common Files\otk\otk_cpp\x86e_win64\obj called otk_install.zip. When the auxiliary application is active I see that the Ribbon has changed and have a new group (20250228_screenshot_1.png).
To save Customized Ribbon I follow the next steps from the User's guide:
1. Go to File -> Options -> Options
2. In "Creo Parametric Options" window go to Ribbon press Export->Save Auxiliary Application user interface.
Then I check resulting toolkitribbonui.rbn (attached) or creo_parametric_customization.ui (depends on Export option) and can read nothing cause the encoding is incorrect.
It seems strange cause initial file otk_install_test.rbn is readable.
What 's interesting is that if I try to import Ribbon from the creo_parametric_customization.ui file, it works seamlessly, which makes me think that this file has a standard encoding for Creo.
What I tried to do:
1. Open the file with different encodings in Notepad and Visual Studio Code.
2. Use python script to open the file in binary format and then guess the encoding using
I found out that there is no necessity to modify directly any *.rbn file to get the Ribbon updated.
I followed the next steps from the html manual (<Creo directory>\Common Files\otk_cpp_doc\objecttoolkit_Creo\index.html) and it worked:
Set the configuration option tk_enable_ribbon_custom_save to yes before customizing the ribbon user interface. The steps to add commands to the Creo Parametric ribbon user interface are as follows:
The code to create a command:
#include <wfcSession.h>
#include <pfcGlobal.h>
#include <pfcCommand.h>
#include <pfcUI.h>
#include <pfcExceptions.h>
#include <wfcClient.h>
#include <fstream>
static ofstream logFile;
class MyCallBack : public virtual pfcUICommandActionListener
public:
void OnCommand();
/* Entry */
extern "C" int user_initialize(
int argc,
char *argv[],
char *version,
char *build,
wchar_t errbuf[80])
try
pfcSession_ptr Session = pfcGetProESession ();
wfcWSession_ptr wSession = wfcWSession::cast (Session);
pfcUICommand_ptr InputCommand1 = wSession->UICreateCommand("My_command", new MyCallBack() );
InputCommand1->Designate ("msg_user.txt", "My_label", "My_help", "My_description");
return (wfcTK_NO_ERROR);
xcatchbegin
xcatchcip (Ex)
logFile << "Exception:\n" << Ex << endl;
xcatchend
/* Exit*/
extern "C" void user_terminate()
logFile<< endl;
logFile<< "================================================" << endl;
logFile<< "OTK application terminated successfully."<<endl;
logFile.close();
void MyCallBack::OnCommand()
try
Session->UIShowMessageDialog("Test succeeded!!", NULL);
xcatchbegin
xcatchcip (Ex)
xcatchend
#include <pfcUI.h>
#include <fstream>
public:
void OnCommand();
/* Entry */
int argc,
char *argv[],
char *version,
char *build,
wchar_t errbuf[80])
try
xcatchbegin
xcatchcip (Ex)
xcatchend
/* Exit*/
logFile<< endl;
logFile.close();
try
xcatchbegin
xcatchcip (Ex)
xcatchend
