Is there a way to change the defaults of these features to 'to next' rather than some randon distantce it auto selects.
You need a productivity option to create Extrude or Hole features with a type of depth set to "To Next" by default. An option to set it is not part of Creo Parametric functionalities.
You might as well file an Product Idea.
A workaround consists in creating a Mapkey.
Hoping this helps.
Hoping this helps.
