FYI
Newbie
FYI
Call logged..........
Currently, there is no system parameter assigned to extract a
sequence's MIN and MAX values. This causes the inability to call out this
information in a drawing's repeat region.
Resolved.......
This issue has been resolved in Pro/ENGINEER Wildfire Datecode
M180
Question.......
Does the resolution now enable you to automatically pull the Z MIN/MAX
values of every sequence into a repeat region of a table, or do you still
need to create a relation parameter for each sequence and then call the
created parameter into your table?
Answer........
Now you can directly call out those parameters in a repeat region.
These are the new parameters that can be called out:
mfg.oper.ncseq.Z_MIN
mfg.oper.ncseq.Z_MAX
mfg.oper.ncseq.X_MIN
mfg.oper.ncseq.X_MAX
mfg.oper.ncseq.Y_MIN
mfg.oper.ncseq.Y_MAX
No relations are necessary.
Life just got a little bit betterSmiley Surprised)
TODD BUSH
JR AUTOMATION
tbush@jrauto.com
616-820-3365
