Hello all,
I recently switched company's and in doing so I am learning Creo now. I have used Inventor for many years before this. I like a lot about the software and still have a few frustrations with the limitations that it has as well from what I am use to. Which brings me to my question is there a way to set up the drawing template or a setting in the software so that my start our as fraction dimensions rather than decimal dimensions? We use fractions for everything but machined parts. So if gets a little frustrating to have to remember to highlight all the dimensions and turn them into fractions after I am done. Thank you for the help.
Familiarize yourself with these options.
Config options
dim_fraction_denominator 64 Change this value to the proper value for your process
create_fraction_dim yes
Drawing setup options
default_tolerance_mode NOMINAL
dim_fraction_format AISC
use_major_units YES
Config options
use_major_units YES
thank you that worked!!!
Don't forget to mark TBraxton's answer as correct for those who may search on this topic in the future.
You may also want to create a couple of mapkeys to change the modeling and drawing settings.
If you can't do a mapkey, try different config.pro files with a Creo launch script that switches between the 2 config options.
