I am using Creo 10.0.7.0.
I have created a table in a Creo drawing where I want to enter values—particularly fractional values—in a specific format, as shown in the first image below. However, I haven’t been able to figure out how to achieve this formatting.
I’ve tried adjusting the config.pro settings and other available options, but it's still not working. Currently, the values appear as shown in the second image. I hope you can see the difference in formatting between the two examples.
probably the only solution is to create custom symbol.
Can you please help me to create that symbol?
In the custom symbol we need to take the numerator and denominator as input from user.
I'm sorry, but I can't do your work.
If you do not know how to create a symbol, then you can use simple solution:
