Currently (XP 32-bit, WF4 M100), we use a fairly typical (I believe)approach for admin of ProE. Loadpoint is in Program Files, with .sup and company .pro in text directory. User .pro/.win located in "home" directory. Certain directories (notes/tables/formats/materials, etc...) are kept on network drive and pointed to. Some items such as company .pro and .sup are copied down to local text directory upon startup of PC via .bat file (generic .bat file which calls a .bat file on the network). I prefer this because I can adjust the .bat file on the network for all users. This has worked great for us thus far. Recently we were given a short amount of time to move to Win7. Not being an IT guy, I'm stuggling a bit with how to accomplish the admin friendly environment we had set up in XP.
With Win7, Program Files is not letting any files be copied in (??). Any time a .bat file is run from the network, the user must OK to continue. There is no C:\Documents and Settings\":User"\Start Menu\Startup directory to put the .bat file in.
So, the Program Files issue is easy enough - install to a different directory. I cannot find a Startup directory - so my thought is to incorporate the xcopy actions intoa .psf file. But this disables the ability to adjust what is being copied unless new .psf files are pushed to the users.
Any suggestions would be great. TIA
Scott
Have you tried running your batch file as administrator (it's a hidden option on Windows 7 )? (right click on the batch and select run as administrator). If this fixes the issue then simply make a shortcut ot your batch on the users machinesand set it torun as administrator ( I don't remember how off hand ).
Also, C:\documents and settings\<username> is still on Windows 7 it is simply hidden but maps to the exact same location as C:\Users\<username>
Hope that helps,
In Reply to Scott Crowe:
Scott
