GTOL Creation for hole Dimension in Drawing
sukpi
7-Bedrock
The following steps are carried out to create GTOL for hole dimension.
1. When we select dimension using Proselect , able to create GTOL
2. ProError lErr = PRO_TK_NO_ERROR;
  ProGtoldata lGtolData;
  lErr = ProGtoldataAlloc((ProMdl )xSolid/*model handle*/ , &lGtolData);
  ProGtoldataStatus lStatus;
  lErr = ProGtoldataTypeSet(lGtolData , xGtolType , &lStatus);
  ProSelection lpSel;
  lErr = ProSelectionAlloc(NULL , &xEdge , &lpSel);
  lErr = ProSelectionViewSet(lView , &lpSel);
  lErr = ProGtoldataReferenceSet(lGtolData , xRefItemType , lpSel , &lStatus);
  lErr = ProGtoldataPlacementSet(lGtolData , PROGTOLPTYPE_DIMENSION, &xDimension , NULL , NULL , NULL,    &lStatus);
lErr = ProGtolCreate(lGtolData , &xGtoL);
lErr = ProAnnotationShow(&xGtoL , NULL , lView);
lErr = ProGtoldataFree(&lGtolData);
Note: ProGtoldataPlacementSet is returning -1. pls help us to solve this issue.
Ketan_Lalcheta
(To:sukpi)
Try using proselectionhighlight once you have set view to selection object..
This highlight would help you to analyze whether selection object is correct or not.
