Get the total count of feature in toolkit
Dhananjayc_24
9-Granite
We want the total count of hole feature in model but avoiding the duplicate hole means. Suppose in part having 10 hole of 5 mm dimension then need to display 5mm hole 10 hole not individually every time.
While you collecting the holes also check the diameter and  position then group it and count it
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
I will get dimension by ProFeatureDimensionVisit() this api but how to group that . WHich API I need to use.
I mean the group is categorize the same hole diameter. There is no specific API needed use your programming skills like if condition to count the specific hole diameter.
while visiting the the dimension get the hole diameter and count it
Parthiban Kannan
We want count in table we want same diameter hole count for that we are doing customization
