The content you are trying to access is permanently deleted.
pro engineer 5.0 run on win7 under vmware.
i'm make sure j-link has been installed.
setup:
1. set working directory to <install path>\...\jlink\jlink_appls\install_test
2. click tools, select auxiliary applications.
3. select <install path>\...\jlink\jlink_appls\install_test\protk.dat
4. name is already in the list
5. select application item, click start, show 'setup of application "InsatllText" failed'
i'm no idea. and can't find any log file.
i'm online waiting for you
thank for all replayer.
test j-link application has work after use jar
The test button appears in the list of file buttons after two steps:
use jar command create jar file from class file.
set 'javar_app_classpath' to protk.dat file.
Thank you for each response, and give me some ideas and methods.
thanks again.
I feel anxious about my English, too. thank translate
Hello, is anyone there?Hello, is anyone there?
This is a user forum, not PTC technical support.
Most users are not at work and won't even see the message until Monday morning, starting in Europe.
So what you mean is that I should not ask this question
No, what he means is that you'll have to have patience.
emmm, my mistake.
thank for u explain.
Did you refer to the java path in the config.pro?
jlink_java_command $JAVA_HOME\bin\java.exe or if Java_Home is not set
jlink_java_command C:\Program Files\Java\jre1.8.0_141\bin\java.exe*
*Use your Java version, not mine.
I have set java environment to classpath and path environment variables.
I did not see the documentation say to be set in config.pro.
thank for u reply!!!
I remember that I set up, but it did not work I was using xdebug to debug, it is certainly set
I suggest you to test old Java versions mentioned in http://support.ptc.com/WCMS/files/107703/en/J-LinkPlatformsWildfire50.pdf document.
thanks, I used the pro engineer 5.0 comes with jre to test
thank for u reply
what Wildfire 5.0 maintenance release do you use ? I mean Mxxx number. Maybe I will be able to run install_test tommorow.
Creo Elements Pro 5.0 M090 Win64
thank for u reply.
thanks again.
I am glad you have got it working.
"Patience is a virtue"
thanks
thanks
I did a short test ...
mh_compile.bat
del *.class
set CLASSPATH=E:\PTC\ProE_Wildfire5_M090\text\java\pfc.jar;E:\PTC\ProE_Wildfire5_M090\text\java\pfcasync.jar;%CLASSPATH%
E:\PTC\j2sdk1.4.1_07_kopie\bin\javac.exe *.java
protk.dat
name InstallTest
startup java
java_app_class StartInstallTest
java_app_start start
java_app_stop stop
allow_stop true
java_app_classpath E:\PTC\ProE_Wildfire5_M090\jlink\jlink_appls\install_test
delay_start false
text_dir E:\PTC\ProE_Wildfire5_M090\jlink\jlink_appls\install_test\text
end
I also got `Install Test Has Failed` .
thanks
