HI ! im trying to Compile wf5 Toolkit applicatios to Creo 3 and i have much problems with the Prodevelope Fuction any one have a solution for that kind of situation? thank you very much !!
Replace the Pro/DEVELOP functions with corresponding Pro/TOOLKIT or Object Toolkit APIs. All of the mapping from 1 API to the other is within the documentation.
anybody have a document that helps migrate a wf 5 vs2008 to vs2015 creo 5
Does this still hold true? for wf5 to creo 5
: Replace the Pro/DEVELOP functions with corresponding Pro/TOOLKIT or Object Toolkit APIs. All of the mapping from 1 API to the other is within the documentation.
which document in creo 5 directory covers mapping from 1 API to the other ? please point me to where it is
Go to the Creo Installation folder
..\(DateCode)\Common Files\protoolkit\protkdoc\
Open the index.html file.
You need to manually the search and get the required API
