Hole callout problem
BobSchwerdlin
3-Visitor
Hi everybody,
One of our manufacturing guys just came up to me with something out of the blue. He stated that drawings in the shop with metric callouts are showing "H CLEAR" in the note when we use the SHOW NOTE command for the hole. In this case the hole is an M8 x 1.25 socket head cap screw C'Bore hole. See attached image of my custom hole table which has all the correct information and bad information on the drawing. Table is truncated in image only.
The only thing I can find in my hole table is "CLASS H" in the header area. Otherwise the letter "H" never shows anywhere else in the entire table. When I query the hole in the model, it is correct.
Any thoughts as to where I need to look to fix this callout on the drawing?
WF 4.0
M080
Bob
0 REPLIES 0
