I am using Creo Parametric - Release 4.0 (connected) Release 4.0 and DatecodeM150
I have a weblink tool which is relied on IE browser and ActiveX, but the IE browser will not be supported in future, how can I continue to use my tool, any alternative method?
please ask PTC Support.
You can use Chromium with weblink. Check documentation.
And ...\Common Files\weblink\weblinkexamples\jscript\pfcUtils.js
Aa ysinitsyn said, you can use chromium and also you can use newer js api creojs instead of weblink (starting with creo 4)
