How to Hide Datum Planes,Points,Curves,etc.. into Layer using ProToolKit API? Please suggest any work around to hide uncontrolled datums into Layer.
ndaslaniya
7-Bedrock
Hide datum’s, axis,points,etc into layers which is not controlled thru layer command.
I have not tried implementation but you can give a try below API:
  • ProLayerItemsGet
  • ProModelitemHide
Thanks and Regards
Ketan
Please find a piece of code I'm using
  // Declarations
ProLine w_old_axis_display;
// Backup current display mode (here for axis only)
ProConfigoptGet(L"axis_display", w_old_axis_display);
// Set your mode
ProConfigoptSet(L"axis_display", L"yes");
// Do what you want
FV
(To:ndaslaniya)
Hi all,
Nikhill, take a look at TestLayer.c in pt_examples directory.
HIH.
Feliks.
