Hide datum’s, axis,points,etc into layers which is not controlled thru layer command.
I have not tried implementation but you can give a try below API:
Thanks and Regards
Ketan
Please find a piece of code I'm using
// Declarations
| ProLine w_old_axis_display; |
| // Backup current display mode (here for axis only) | |
| ProConfigoptGet(L"axis_display", w_old_axis_display); | |
| // Set your mode | |
| ProConfigoptSet(L"axis_display", L"yes"); | |
| // Do what you want |
Hi all,
Nikhill, take a look at TestLayer.c in pt_examples directory.
HIH.
Feliks.
