How to Move a drawing Note From one view To Another
KB_9753804
Hi ,
In Creo 4.0  M140 , there is command called "Move to view " which is used to move an annotation from one view to another view , I have do this using API & I m using ProToolkit , Please help me out with solution
Kunal
7 REPLIES 7
remy
(To:KB_9753804)
Your application needs to perform the equivalent of RMB on a Drawing view > Move to View. This is a typical instance where a dedicated function exists.
When you search the API documentation with *viewmove" you will find
ProDrawingViewMove
and bonus: pt_examples will give you some code.
KB_9753804
(To:remy)
This API is used to position view not to move annotation from one view to another
Kunal Bidkar
remy
(To:KB_9753804)
That's partially right: this function enables to move a Drawing Note to a different view.  This is my understanding of the topic : "How to Move a drawing Note From one view To Another".
Can you share a screencapture of the operation that you need to run with toolkit? or share some model (even a dumb one)?
By chance do you mean the RMB > Move to plane operation?
pausob
(To:remy)
?? the suggested API function does not seem to apply to the correctly stated problem: Your application needs to perform the equivalent of RMB on a Drawing view > Move to View
remy
(To:pausob)
You are right the command you referred to is Move to View when RMB a drawing dimension for example:
To get an actual function to perform the equivalent, an enhancement request is required.
Else follow @FabianWolf suggestion.
FabianWolf
(To:KB_9753804)
Example for a 2D note:
  • ProDtlnoteDataGet()
  • ProDtlnotedataAttachmentGet()
  • ProDtlattachGet --> Third arg is the current parent view
  • ProDtlattachSet() --> Supply args returned by ProDtlattachGet() except for the ProView (use the view to be the new parent of the annotation)
  • ProDtlnotedataAttachmentSet()
  • ProDtlnoteErase()
  • ProDtlnoteModify()
  • ProDtlnoteShow()
Works pretty similar for symbols.
Hope that helps.
FabianWolf
(To:FabianWolf)
Did this solve your problem?
