How to Read phantom Components Parameter Using VB API?
yshinde
Hi All I want to get the parameter from phantom component i tried bellowed code but it doesn't work !
  NewModel = BSession.RetrieveModel(modelDesc)
  ParamOwner = CType(NewModel, IpfcParameterOwner)
Code failed at 1st line .
is there any work around ?
yshinde
(To:yshinde)
As we can not open phantom component in new window then how to access their parameters?
Manually we can go to parameter table by using "Edit Parameter" option.
any one Please  help
Hello Yogesh,
Please share your error details to find out the problem
See this link about how to get parameter
Re: How to get parameter values by API
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
