How to Redefine Hole
KB_9753804
Hi ,
I want to redefine the hole feature , for this I extract the element Tree and try to add element of standard hole parameter like Hole Series and Hole Size in same , But it is nor working Can you help me to resolve the issue .
Thanks & Regards,
Kunal Bidkar
FV
(To:KB_9753804)
  • manually redefine a hole feature and output its elemtree to XML,
  • modify elemtree of another hole feature and output the modified elemtree into XML,
  • compare two XML files...
KB_9753804
(To:FV)
Does we need to create complete tree for redefining the hole feature ?
Thanks & Regards,
KB
FV
(To:KB_9753804)
take a look at UgMfgWcellCreate.c in protk_appls directory.
It shows a workflow for the feature redefinition process:
HIH
