This discussion is my reaction to CSYS name should alway be the Part Name idea.
Attached CSYS_rename_CR3_prvek4.zip file contains following files:
How to install script:
How to run script:
Notes:
Good luck !
Martin Hanak
Hi Martin!,
Thank you for this tool with source code. This gives a whole new level to Creo Mapkeys combined with external application. And it's pretty clever how you did the renaming.
I didn't know, something like this is possible! I cannot say my thanks with words!
I wanted to ask, if you could share the $F2-mapkey you are using for this renaming method of CSYS. I have original scripts from IPM with $F2 for opening model tree, so the .exe files don't work for me.
Thanks again and I wish you the best!
I don not understand well your last paragraph:
My guess ... you want call mapkey by clicking F2 key instead of clicking dd1 key combination. If this is the case then simply change config.pro line using Notepad.
mapkey dd1 @SYSTEMstart C:\\PTC\\CSYS_rename_CR3_prvek4\\rename_csys_prt.exe;
to
mapkey $F2 @SYSTEMstart C:\\PTC\\CSYS_rename_CR3_prvek4\\rename_csys_prt.exe;
MH
I think he was looking at the .au3 source code which calls the F2 key
This method will rename the csys to match the part number only or will it automatically match the csys name when I create a new part?
the mapkey renames coordinate system (feature no.4) in model tree.
MH
Not useful solution
Not useful solution
Not a usable solution.
You are almost right, but p-Shell is running in a SandBox, you need to copy one folder only.
The "PNG" shows the env, the movie shows what happen if you add a new folder to your SandBox programs.
This is not a final app, but should show how easy it is to make an update or test new code.
Note: This Tcl program run in synchronous mode.
Cheers
Does p-Shell ship from PTC?
Ha, as I guess you work for PTC, and this is not from PTC ![]()
If I worked for PTC then I would have a PTC badge.
Feel free to link to the source.
Use the mail address from the Wiki to get more information.
100 Kudos for this statement ![]()
functionality can be customized by toolkit for open/rename/saveas/import
