How to change the default action in conflict prompt
RobrechtSavaco
Is there a way to change the default action in the conflict prompt from "Check out now" to "Make Read-only" for example? 
Kind regards
Robrecht
TomU
(To:RobrechtSavaco)
Not, via this dialog.  You can default to the other values.  See https://www.ptc.com/en/support/article/cs44835
For 'Read Only', consider setting the Windchill preferences that automatically set everything added to your workspace as read only.
https://www.ptc.com/en/support/article/cs76228
https://www.ptc.com/en/support/article/cs334870
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FCADxFileMenuObjAdd.html
TomU
(To:RobrechtSavaco)
RobrechtSavaco
(To:TomU)
Fantastic, thank you for the all the information on this topic!
Kind regards
Robrecht
Rami_Noah
(To:TomU)
while it's true and working for Creo - why not to support same scenario q use case for other workgroup managers ( Solidworks etc ) ?
just opened an Idea for that - Auto-suppress-the-quot-Check-Out-on-the-Fly-quot-for-WGM
your voting will be appreciated
