This is mentioned in the VB API documentation:
"Support for Embedded OLE Objects
OLE objects, when activated by the user, can include VB code that can be used to drive the model from which the object is contained. The VB API provides a special property in embedded Microsoft Word, Microsoft Excel and Microsoft PowerPoint documents that can directly return the connection ID of the Creo Elements/Pro session that launched the process containing the OLE object."
Does anyone have an example of how to get the value of that property ?
