Hi all,
I still have a TS call open but for sure someone will answer me there ![]()
I'm trying to create varied items on an inheritance feature using Pro/Toolkit
Varied dimension creation is ok but I cannot find a way to create varied parameter or varied feature
Perhaps I've to use otk or jlink instead of toolkit.
Thanks in advance
Hi Frédérick,
I am also working on inheritance nowadays, but it is unsuccessful, it always told me "BAD_INPUT", can you share me your code about this?
I have a dozens of parts need to inheritance automatically, don't need to create the varied items, just only inheritance.
my email address: -
I am very appreciate if you can share me. thanks!
Here is my code, but it doesn't work, I can't figure out why? Can you help me?
FUNCTION : ProTestInheritMerge ()
PURPOSE : Inherit Merge general merge feature .
void ProTestInheritMerge ()
ProError err;
ProElement elem_root;
ProSelection sel;
ProModelitem modelitem;
ProErrorlist errors;
ProFeature feature;
ProFamilyName comp_name;
ProModelitem item_asm_csys,item_comp_csys,comp_item;
ProName asm_csys,comp_csys;
ProMdl assembly,component;
ProSelection _asm_csys,_comp_csys,comp_mdl;
err=ProMdlCurrentGet(&assembly);
if (err != PRO_TK_NO_ERROR)
AfxMessageBox(L"ProMdlCurrentGet failed!");
return;
ProStringToWstring(comp_name,"prt0001.prt");
err=ProMdlRetrieve(comp_name,PRO_MDL_PART,&component);
ProStringToWstring(asm_csys,"INSTALL");
ProStringToWstring(comp_csys,"INSTALL");
err = ProModelitemByNameInit(assembly,PRO_CSYS,asm_csys,&item_asm_csys);
AfxMessageBox(L"ProModelitemByNameInit((ProMdl)assembly failed!");
return;
err = ProModelitemByNameInit (component, PRO_CSYS,comp_csys, &item_comp_csys);
AfxMessageBox(L"PRO_TK_BAD_INPUTS");
return;
ProAsmcomppath comp_path;
ProIdTable c_id_table;
c_id_table [0] = -1;
err =ProAsmcomppathInit ((ProSolid)assembly, c_id_table, 0, &comp_path);
AfxMessageBox(L"ProAsmcomppathInit failed!");
return;
err = ProSelectionAlloc (&comp_path, &item_asm_csys, &_asm_csys);
AfxMessageBox(L"ProSelectionAlloc failed!");
return;
err = ProSelectionAlloc (NULL, &item_comp_csys, &_comp_csys);
AfxMessageBox(L"ProSelectionAlloccomponent failed!");
return;
ProFeatureCreateOptions opts[] = {PRO_FEAT_CR_INCOMPLETE_FEAT};
static ElemTreeData tree[] = {
{0, PRO_E_FEATURE_TREE,{(ProValueDataType)-1}},
{1, PRO_E_FEATURE_TYPE, {PRO_VALUE_TYPE_INT, {PRO_FEAT_GEN_MERGE}}},
{1, PRO_E_GMRG_FEAT_TYPE, {PRO_VALUE_TYPE_INT, {PRO_GEN_MERGE_TYPE_MERGE}}},
{1, PRO_E_DSF_REF_MDL, {(ProValueDataType)-1}},
{1, PRO_E_GMRG_MATERIAL_OPT, {PRO_VALUE_TYPE_INT, {PRO_GEN_MERGE_ADD_MATERIAL}}},
//{1, PRO_E_GMRG_VARIED_ITEMS, {(ProValueDataType)-1}},
//{1, PRO_E_GMRG_COPY_DATUMS, {PRO_VALUE_TYPE_INT, {PRO_B_FALSE}}},
//{1, PRO_E_DSF_PROPAGATE_ANNOTS, {(ProValueDataType)-1}},
//{1, PRO_E_DSF_DTMS_FIT, {(ProValueDataType)-1}},
{1, PRO_E_DSF_DEPENDENCY, {PRO_VALUE_TYPE_INT, {PRO_DSF_ANNOT_DEPENDENT}}},
//{2, PRO_E_DSF_ANNOT_CPY_ALL, {PRO_VALUE_TYPE_INT, {PRO_B_TRUE}}},
//{2, PRO_E_DSF_ANNOT_DEPEND_ALL, {PRO_VALUE_TYPE_INT, {PRO_B_TRUE}}},
//{2, PRO_E_DSF_ANNOT_AUTO_CPY_DTM , {PRO_VALUE_TYPE_INT, {PRO_B_TRUE}}},
{2, PRO_E_DSF_EXT_LOCAL_TYPE, {PRO_VALUE_TYPE_INT, {PRO_DSF_PLACE_EXTERNAL}}},
{2, PRO_E_DSF_SEL_REF_MDL, {PRO_VALUE_TYPE_SELECTION}},
{2, PRO_E_DSF_PLACEMENT , {(ProValueDataType)-1}},
//{2, PRO_E_DSF_DTM_FIT, {(ProValueDataType)-1}},
{3, PRO_E_COMPONENT_CONSTRAINTS, {(ProValueDataType)-1}},
{4, PRO_E_COMPONENT_CONSTRAINT, {(ProValueDataType)-1}},
{5, PRO_E_COMPONENT_CONSTR_TYPE, {PRO_VALUE_TYPE_INT, {PRO_ASM_CSYS}}},
{5, PRO_E_COMPONENT_COMP_CONSTR_REF, {PRO_VALUE_TYPE_SELECTION}},
{5, PRO_E_COMPONENT_ASSEM_CONSTR_REF, {PRO_VALUE_TYPE_SELECTION}}};
Prepare value for the component model element.
err=ProMdlToModelitem(component,&comp_item);
err = ProSelectionAlloc (NULL, &comp_item, &comp_mdl);
AfxMessageBox(L"ProSelectionAlloc ProMdlToModelitem failed!");
return;
tree[7].data.v.r = comp_mdl;
Prepare value for the component and assembly reference element.
tree[12].data.v.r=_comp_csys;
tree[13].data.v.r=_asm_csys;
Create element tree
err = ProUtilElemtreeCreate(tree, sizeof(tree)/sizeof(tree[0]),NULL, &elem_root);
AfxMessageBox(L"ProUtilElemtreeCreate failed!");
return;
Set up a selection structure for the feature context.
err = ProMdlToModelitem (assembly, &modelitem);
AfxMessageBox(L"ProMdlToModelitem failed!");
return;
err = ProSelectionAlloc (NULL, &modelitem, &sel);
return;
Assemble the component by feature creation.
err = ProFeatureWithoptionsCreate (sel, elem_root, opts,
sizeof(opts)/sizeof(opts[0]), &feature, &errors);
AfxMessageBox(L"Assembly failed!");
if (err == PRO_TK_BAD_INPUTS)
AfxMessageBox(L"PRO_TK_BAD_INPUTS!");
Free Allocated memory
err = ProElementFree(&elem_root);
err = ProSelectionFree(&sel);
ProSelectionFree(&_asm_csys);
ProSelectionFree(&_comp_csys);
ProSelectionFree(&comp_mdl);
Function: ProUtilElemtreeCreate
Purpose: Create element tree by the ElemTreeData structure
Return : PRO_TK_NO_ERROR if successfull,
ProError ProUtilElemtreeCreate(
ElemTreeData *elemarr, /* In : The array of ElemTreeData */
int n_elem, /* In : number of ElemTreeData in elemarr */
ProElement base_tree, /* In : the base tree */
ProElement *elem_tree) /* Out : element tree */
ProElement elem_level[10], elem;
ProValue value;
int i;
ProError err;
if (base_tree!=NULL)
elem_level[0] = base_tree;
for (i=0; i<n_elem; i++)
err = ProElementAlloc((ProElemId)elemarr[i].elem_id, &elem);
return (err);
if (elemarr[i].data.type != -1)
Add Element value
err = ProValueAlloc(&value);
return (err);
err = ProValueDataSet(value, &elemarr[i].data);
return (err);
err = ProElementValueSet(elem, value);
return (err);
Add Element to the tree
if (elemarr[i].level!=0)
err = ProElemtreeElementAdd(elem_level[elemarr[i].level-1], NULL,
elem);
elem_level[elemarr[i].level] = elem;
elem_tree[0] = elem_level[0];
return (PRO_TK_NO_ERROR);
