How to create electrodes from surfaces
FlorianHammrich
This short guide explains how to create electrodes with surfaces in SMARTElectrode‌:
# Description Selection Result
1.
"Add" new electrode
Select burn-faces and press Strg+c and Strg+v
or press "CopyGeometry".
2.
Activate filter for boundary edges
Select start and end of chain
Convert to "Edge-Chain" in context menu
Use "Extend in Direction" from context menu
and choose direction
3.
Select curve chain
Use "Extend" from context menu
Choose method tangent and set distance to extend
Apply changes
4.
5.
Activate filter for quilts and select quilt
Use "Attach" to connect with FREE_FACE and to create a solid
"Attach and add support" is also accessible for quilts
6. Use "Mirror" and select surface to mirror solid 2016-09-14_023.png 2016-09-14_024.png
7.
Add "Base"
Florian Hammrich
B&W Software GmbH
0 REPLIES 0
