I am trying to simulate a chassis front panel that has silkscreen information on it. I can apply the font correctly (Arial Narrow), but the characters are outlined, not filled. Does anyone know how to fill the fonts? I'm trying to output a JPEG file for Marketing approval and it does not look very good with the outlined fonts. By the way, I'm referring to the modeling environment, not drawing or sketcher. Thanks, Tom C.
If you can extrude them slightly into the part (.003"). Then you can color the surface to the color you want and make them pop-out.
Thanks, Dale
I agree with Dale, this is what I regularly do.
