The toolkit get resource(TEXT_DIR) only once when a start Auxiliary Applications for one.
So another toolkit app can not get a resource(UI files, msg_file, etc..) they need to start or use it.
Because "Second-TKAPP" starts after "First-TKAPP", only the resource of "First-TKAPP" is obtained, not the resource "Second-TKAPP".
As the toolkits are launched in different locations, is there a way to get their respective resources?
Warm Regards,
SeonHo Cha.
Make sure that the resources have unique names for both applications.
E.g. by using prefixes: "app1_messages.txt" and "app2_messages.txt". Now both files are read-in by Creo no matter which app starts first.
Same for images dialog res files.
