How to get the info of datum (name, ...)
JB_87049
I have an annotation with type PRO_SET_DATUM_TAG.
ProAnnnotation Annotation
Annotation.type == PRO_SET_DATUM_TAG
How can I retrieve the data of this annotation, like name, ...?
I'm using Toolkit wit PTC Creo Parametric 6.0.4.0
Any advice is much appreciated.
JB_87049
(To:JB_87049)
After debugging and looking at the structure of the data type I have tried something different.
I have now applied ProSetdatumtagLabelGet(). This seems to do what I want.
Thank you very much for pointing me into the right direction.
remy
(To:JB_87049)
JB_87049
(To:remy)
Thank you for your response. I haven't tried this one yet.
I'm scanning annotations with ProCombstateAnnotationsGet.
When the type of an annotation in the returned annotation array is PRO_SET_DATUM_TAG I would like to retrieve the name.
What I will try now is to use the calls ProSolidSetdatumtagVisit and ProSetdatumtagReferencesGet(). I fear however this is about the tags of real datum planes which is not necessarily the case when using 3D annotations.
JB_87049
(To:JB_87049)
