How to load a protoolkit application (protk.dat) from user defined location without config.pro
DH_10786687
8-Gravel
Description :
How to load a protk.dat in Creo parametric, if the protk.dat file is at a user defined location without editing the config.pro file
Use Case -
I have protk.dat file located at C:\temp & would like to load this application in Creo whenever it is launched.
Also, without copying the .dat file to the <Creo load point>/Common Files/text.
Tried setting up Environment variable "HOME" pointing to C:\temp, but it is not working.
Thanks.
Ben_C
(To:DH_10786687)
By using 'cd' in the batch file, you can change the current directory before launching Creo,
e.g. to change to the directory the bat file is run from:
cd /d "%~dp0"
"C:\Program Files\PTC\Creo 10.0.0.0\Parametric\bin\parametric.exe"
or to always set it start dir to C:\Temp :
cd /d "C:\Temp"
6 REPLIES 6
Ben_C
(To:DH_10786687)
You just need to set the start directory to be where the protk.dat exists, in your case C:\temp
If you have a desktop shortcut, you can modify the properties to change the start directory:
remy
(To:Ben_C)
Also if you are using 9.0.2.0 and more you can set the environment variable PTC_CREO_ALT_SETTINGS_PATH
More about it here : https://www.ptc.com/en/support/article/CS384810
Yes, I have already tried this & works out.
But I am looking for older Creo version starting from Creo 7.0.0 & above.
Thanks for that.
Is there any other way around as I am launching Creo using a batch file. Can it be done using the environment variable or editing the Creo default registry file or something else.
Ben_C
(To:DH_10786687)
cd /d "%~dp0"
cd /d "C:\Temp"
This helped. Thanks for that!
