How to select the Datum plane from Model Tree by Program itself instead if User Interactive Selection?
PARTHIBAN_K
Hi All,
  I am planning to create the Extrude feature by Toolkit Program in predefined datum plane as reference. Since I know the plane exactly where would be the extrude. I won't like to make the user  to select the plane as user interaction method. So anybody let me know how to do this.
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
GabrielZaha
(To:PARTHIBAN_K)
You will need to use the ProSelectionAlloc function. If you are working within a part model the ProAsmcomppath member (first argument) can be NULL.
To get the modelitem handle you can use either ProModelitemInit or ProModelitemByNameInit.
GabrielZaha
(To:PARTHIBAN_K)
Hi Gabriel,
I have utilized ProModelitemByNameInit.
Parthiban Kannan
