As said in the title, i would like to switch Creo language (French / English) with a parameter.
Is there a parameter to do this ?
Thanks for your help,
Regards
solution no.1
Add following options into config.pro file:
DIALOG_TRANSLATION no
HELP_TRANSLATION no
MSG_TRANSLATION no
MENU_TRANSLATION no
solution no.2
Add following line at the end of parametric.psf file:
ENV=PRO_LANG=english
