Dear Community,
inside OTK Java free I am registering another JLink application using BaseSession::StartJLinkApplication. This works fine. JLinkApplication::IsActive returns true and I can see the registered app in Creo (4.0). Furthermore I can register a task by using BaseSession::RegisterTask. But if I want to excecute the task (JLinkApplication::ExecuteTask) with the same TaskId that I used for registering the task I get a XToolkitNotFound exception. If I want to register another task with the same TaskId I get a XJLinkTaskExists exception.
I do not understand why! I also do not understand why I have to register a task on the BaseSession object but execute it on the JLinkApplication object.
Could anybody help?
Thank you and kind regards
Michael
It got it working now. As a matter of fact the registering of the task needs to happen inside the external application. That's where I got it wrong before. If you are interested see my example code.
The base application executing the task of the external application:
public class ExternalJLinkApplicationLauncher extends DefaultUICommandActionListener {
@Override
public void OnCommand() {
try {
JLinkApplication externalJLinkApp = pfcGlobal.GetProESession().StartJLinkApplication("externalJLinkApp",
"com.testing.ExternalJLinkApplication", "start", "stop", "C:\\path\\to\\classfiles", "C:\\path\\to\\textfolder", true);
String taskId = "externalJLinkApp001";
Argument dummyArgument = pfcArgument.Argument_Create("dummyArgument", pfcArgument.CreateASCIIStringArgValue("value"));
Arguments arguments = Arguments.create();
arguments.append(dummyArgument);
try {
externalJLinkApp.ExecuteTask(taskId, arguments);
} catch (XToolkitNotFound e) {
System.out.println("Task could not be found in target application.");
} catch (jxthrowable jxt) {
System.out.println(jxt.getMessage());
class ExternalJLinkAppListener extends DefaultJLinkTaskListener {
@Override
public Arguments OnExecute(Arguments arg0) throws jxthrowable {
System.out.println("externalJLinkApp started.");
return arg0;
The external application:
public class ExternalJLinkApplication {
private void registerTask() {
try {
try {
pfcGlobal.GetProESession().RegisterTask(taskId, new ExternalJLinkAppListener());
} catch (XJLinkTaskExists e) {
System.out.println("Task " + e.GetTaskId() + " already exists.");
return;
public static void start() {
ExternalTestApp instance = new ExternalTestApp();
instance.registerTask();
public static void stop() {
@Override
new JwPrintMessage().messageArea("TEST");
System.out.println("ExternalJLinkApplication started.");
return arg0;
Thank you all for your support and best regards!
I found only one article that is at least somehow related to your question: https://www.ptc.com/en/support/article/cs331890
please ask PTC Support.
Difficult to understand what happened without a sources. Could you provide a sample of your code?
Thank you all for your replies! I will post the code as soon as I have some time, latest this weekend...
Kind regards
Michael
You're welcome.
@Override
try {
try {
@Override
return arg0;
try {
try {
return;
@Override
return arg0;
