I have a problem in Creo 7.0, when I try to import an IDF with some small components in it. I get a warning that asks me to change the sketch. I found where the problem comes, I need to use the inlbs_part_ecad_rel.prt not the inlbs_part_ecad_abs.prt template. I renamed it and it works very well.
But I am looking for a cleaner way to use it.
Is there an option in config.pro which allows to replace the inlbs_part_ecad_abs template into inlbs_part_ecad_rel when used for importation? I already tried template_ecadpart option, but no change.
Thank you! 😊
The option specifying the template for an ECAD part is:
Hello!
Sure! It helps me figure out the issue. It was prevented by a macro.
Thank you very much!
Unfortunately, I am not allowed to post the IDF. Sorry!
