I'm using Creo 12.4.0.0 and I'm experiencing an issue when trying to edit certain configuration files in Creo ModelCHECK. Here is the situation:
I can edit Start Files and Status Files under the Configuration Files section without any problem.
However, when I try to edit files under Check Files or Constant Files, Creo crashes.
For example, I tried openin the default_checks_mch, file but Creo immediately crashes.
The crash only happens when editing Check/Constant files, not Start/Status files.
Hi @SD_13694836,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
