Issues with Asynchronous and Multiprocess Application Methods in Creo Toolkit
AS_13847166
7-Bedrock
Hello Community,
I am working with Creo Toolkit and exploring three different methods of application creation:
  1. Asynchronous Method
    • I am using the API ProEngineerConnect() which refers to the library pt_asynchronous.lib.
    • Even though I have included this library under Linker → General → Additional Library Directories, I am getting the following compile-time error:
      identifier "ProEngineerConnect" is undefined
  2. Multiprocess Method
    • When I use the generated DLL in another C# WinForms application, I encounter this runtime error:
      Unable to load DLL "DLLNAME.dll" or one of its dependencies: The specified module could not be found. (0x8007007E)
Could anyone help me understand:
  • Why is ProEngineerConnect() not recognized even after linking the correct library?
  • What could be causing the DLL load failure in the C# application?
  • Are there any best practices or additional steps for setting up asynchronous and multiprocess methods in Creo Toolkit?
Any guidance or examples would be greatly appreciated.
RPN
(To:AS_13847166)
Are you making sure that all required Creo DLL’s are in your path var prior to load? The obj machine path must be know. For the link error I guess the lib or the header file is still unknown.
