Hello I use J-Link more then Toolkit because J-Link does everything that I want to do and most of my customers are now using J-Link. You are correct on the 40% but Java supplies alot of functionality and Java is easer to use then using C. Since WF came along, J-Link has drawing functionality and J-Link is increasing its functions each version of Pro/E. It depends on what you want to do to detemine if Pro/TOOLKIT is the correct API to use or if J-Link is the correct API to use. There is a J-Link course that Felco Solutions offer. Go to www.felcosolutions.com to find out more information about the course. Thanks and good luck.
"Anatoly Pilikov" wrote:
Good day! There is a question that I want you to ask. I want your opinion about how large the functionality of JLink now is. is it equal to pro/toolkit or less? As I know the functionality of jlink is something about 40% from functionality of pro/toolkit. please your comments ))
