I wonder if anyone had installed Pro/Mechnica Motion with the settings
indicated in the installation guide.
We have MS Visual C++ version 6 installed, which is required for Motion.
I need to know how did you guys set the (full) path of the MM_C_HOME
variable. I need to know what Motion activates (what .exe file) when it
summons C++.
I wonder if Windows XP is the culprit; I assumed that I should be using
the i486_nt executable.
We will not have Wildfire with the MDO module and will keep for a while
our old licenses for Pro/Mechanica.
Thank you for suggestions.
Michael
