Medium Fit for Thru Holes in UNC Hole Tables
ptc-2513036
I have been trying to incorporate all callout notes for ISO and for UNC/UNF into two tables. This includes all of our applicable scenarios: Tapped, Clearance, C'BORE and C'SINK.
Did this by adding a DEFAULT_CALLOUT_FORMAT_DATA section to each table and it works brilliantly.
The only problem I have is that my UNC/UNF (INCH) table will not display the Medium Fit option when defining a Clearance hole.
The UNC/UNF (INCH) table (In Testing) was created after the ISO table was completed and deployed by doing a save as from the ISO table and updating the THREAD_DATA values.
Does anyone have any tips for resolving this issue?
Jason Knighten
TomU
(To:ptc-2513036)
Medium fit is only valid and displayed when the hole table is using metric units.
[cid:image001.png@01CE3516.CDC119A0]
Tom U.
TomU
(To:ptc-2513036)
No idea. Asking ‘why’ about PTC products usually doesn’t lead to a satisfying answer.
Why can’t holes change size via relations (1/2-13 to 3/8-16, etc.)?
Why can’t holes change size via a family table?
Why can’t thread depth be controlled independently?
Why can’t drill depth be controlled independently?
Why haven’t the hole tables been updated/expanded since version 24 (22 for UNF)?
… and on and on.
It’s no wonder people are forced to create their own custom holes and the tools to use them.
Tom U.
