I was trying to create a basic code in Vb which allows me to connect to Creo Parametric. I followed the first steps so, I added PRO_COMM_MSG_EXE to System variables, I ran as administrator vb_api_register.bat and I added Creo Parametric VB API Type Library for Creo Parametric to my VB.NET project.
When I try to compile my code, ToolkitCantModify execption appears. Here is my code so I would appreciate if someone could check it because I don´t know if I did something wrong.
Many thanks!
could anyone resolve my issue?
I have been searching some info during these days, but i haven't found anything clear. I tried to set up VB Api configuration again but it didnt work.
Thanks in advance.
You're much more likely to get help with VB API on the Creo Parametric Customization board. You can also find a lot of good information by searching that board for 'VB API'.
Hi Askarke,
I have moved your post to the Creo Parametric Customization board.
Anurag
