Hello all,
Need an idea to retrieve GD&T Feature Frame symbol from 3D Notes into MS-Word document.
(Using VB API or J-Link)
okk,
First u will takes the notes as string.
after use some regex that matches with GD&T symbols.
and also make some dictionary like this
this dictionary is used for replace the Unicode with Symbols.
get iterate with string and regex .
if the string match with regex, it will retreive that Symbols.
1. regular expressions
2. using ProDtlnotelineTextsCollect()
Each line of note can contain numerous ProDtlnotetext.
For example (past this text to Note properties)
"UNLESS OTHERWISE SPECIFIED, RADII {1:XXX#1} {3:mm}"
{1:XXX#1} - this is ProDtlnotetext one
{3:mm} - this is ProDtlnotetext two
Thank you YaroslavSin.,
I have retreived by another method
Good job!
Feel free to share your method to the community.
okk,
