Note attached to a surface.
LH_10747950
SO I'm making a project to calculate the surface areas of a sheet metal part that has a surface finish, two types "finish1" and "finish2", but I only have access to the free java object toolkit. I know I cannot use the surface finishes nor the annotations. I had an idea to attach a note of a specific type to a surface with a surface finish and then get the surface its attached to then get its area. Is this possible? I've tried GetAttachment() as it is a DetailNoteItem and doing GetParent which  returns with the part which I think isn't helpful as i none of the model items from that are surfaces. Is there another way?
	//Surface Finishes
	private HashMap <String, Double> getFinishes(Solid solid){
		double finish1 = 0;
		double finish2 = 0;
		HashMap <String, Double> finishes = new HashMap <String, Double>();
		try {
		ModelItems modelItems = solid.ListItems(ModelItemType.ITEM_DTL_NOTE);
		for (int i = 0; i<modelItems.getarraysize(); i++) {
			ModelItem modelItem = modelItems.get(i);
			printMsg("modelItem: " + modelItem.GetName());
			DetailNoteItem detailNoteItem = (DetailNoteItem) modelItem;
			DetailTextLines textLines = detailNoteItem.GetTextLines(DetailTextDisplayOption.DISPMODE_NUMERIC);
			for (int j=0;j<textLines.getarraysize();j++) {
				DetailTextLine textLine = textLines.get(j);
				DetailTexts texts = textLine.GetTexts();
				for (int k =0;k<texts.getarraysize();k++) {
					DetailText text = texts.get(k);
					String note = text.GetText();
					//printMsg("note: " + note);
					if (modelItem.GetName().equals("Note_24")){
						printMsg("Note: " + note);
						try {
						DetailAttachment detailAttachment = detailNoteItem.GetAttachment();
						printMsg("got attachment");
						printMsg("Attachment: "+ detailAttachment);
						catch (jxthrowable e) {
							e.printStackTrace();
						try {
						Parent parent = detailNoteItem.GetDBParent();
						printMsg("got parent");
						printMsg("Parent: " + parent);
						Part parentPart = (Part) parent;
						ModelItems parentModelItems = parentPart.ListItems(null);
						for (int l = 0; l<parentModelItems.getarraysize();l++) {
							ModelItem parentModelItem = parentModelItems.get(l);
							//printMsg("modelItem: "+ parentModelItem);
						try {
						Child child = detailNoteItem.GetChild(null);
						printMsg("got child");
						printMsg("Child: " + child);
		finishes.put("finish1",finish1);
		finishes.put("finish2",finish2);
		}catch (jxthrowable e) {
		return finishes;
tbraxton
(To:LH_10747950)
Have you considered datum analysis features within the model to calculate the areas? These features include parameters for the surface area that can be used in a note.
Involute Development, LLC
Consulting Engineers
I have not tried it, I'm still new to Creo so I've never used them before and the article To_Create_an_Analysis_Feature doesn't seem too helpful as I don't know what definition or type I should use. would it be okay for you to give me a quick run down on the basics of these? Thanks!
