Orient flat state on a drawing
akok
Hi
I need to have the flat state placed flat on the drawing, for the lasercutter.
Is there a way to do this?
I'm thinking, create a saved orientation and use this on the drawing.
I doesn't matter how the part is oriented, just it is flat.
Allan
JB_87049
(To:akok)
I have made a short video showing you how you can use flat states in a drawing.
It is attached to this message.
Hopefully this is what you are looking for.
akok
(To:JB_87049)
Thank you.
My problem is, I will like to automate the process you showed.
I will like the get Jlink to first make the flat, here after put the flat on the drawing on sheet 2, orientated flat in 1:1 scale.
My problem is I don't know how to orient it flat.
Allan
JB_87049
(To:akok)
I can not help you with doing that using JLink, but can't you do it using a mapkey?
akok
(To:JB_87049)
Proberly I can use a mapkey, do you know how to orient with a mapkey?
