Parametric text
sammy1994
11-Garnet
Parametric text
I have to put some text on my model. So i go to extrude- select the face of the model where i want to put the text- select use parameter.
When i change the value of parameter in the BOM, the text which is linked to that parameter does not change.
Is there any way to change the paramter linked text automatically??
please explain how do you change the value of parameter in the BOM.
I changed parameter value in model tree column ... it worked well.
Martin Hanák
This is how i change the parameter value
so ... you do not use OOTB Creo functionality. Instead of it, you use functionality of EMX (Expert Moldbase Extension) developed by B&W software. Maybe @tschneyer  can answer your question. I guess BOM information is not associative with model.
Martin Hanák
Okay thanks a lot for your response
