3-Newcomer
July 3, 2025
Position of flexible parts
- July 3, 2025
- 1 reply
- 994 views
I've attached an example with two flexible assemblies. Each of these assemblies contains two parts whose x-position is controlled using a variable dimension. Now my task is to get the "actual" position as it can be seen in the main assembly. I obviously can't use wfcWComponentFeat::getPosition as this gets me the "as constructed" position. I tried to call wfcWComponentFeat::Refresh and wfcWComponentFeat::RefreshRelations before calling getPosition but this hasn't changed anything... Do i have to calculate the correct position myself or is there some kind of "trick" that i have to do in order to get the correct position?
Christoph
