Is it possible to automate Pro/Batch?
- i.e. Can I run Pro/Batch every night on a certain set of directories and make plot files for all files in the directory? I suppose if I could run Pro/batch from the command prompt with some variables? I am looking for an easy way to generate pdf's for others in the organization to view and keep them up to date relative to the actual Pro/E files.
Bill
