Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
All, I got it to work properly using a MFC DLL project. There are quite a few steps to follow to successfully get a dialog displayed so if anyone wants to know how then let me know and I'll spend the time to do so.
Patrick Williams Sr. Systems Engineer II Mechanical Engineering Solutions Missile Systems Raytheon Company
TU/M12/8 6221 S Palo Verde Rd Tucson, AZ 85706 USA www.raytheon.com
This message contains information that may be confidential and privileged. Unless you are the addressee (or authorized to receive mail for the addressee), you should not use, copy or disclose to anyone this message or any information contained in this message. If you have received this message in error, please so advise the sender by reply e-mail and delete this message. Thank you for your cooperation.
