Good day --
I am trying to set up and configure a test environment to install some of the old libraries.
One specific issue I am encountering is setting up the configuration to run properly.
Here is one specific example:
- Run the connector library set up
- Install the files
- RUN \connlib\bin\i486_nt\mkconnconfig.exe
- ENTER PATH for Library Loadpoint Directory
- Filename contains spaces
- ERROR: X:\XXXX - invalid directory
I have tried using "" 's and double "" 's when inputting the location. Same results each time.
Any suggestions would be greatly appreciated.
Thanks in advance.
Aaron Spicer
