"Rameet Grewal" wrote:
Hi Dooting, You can have a look at the supported compilers for ProToolkit for Pro/E Wildfire 3.0 at http://www.ptc.com/WCMS/files/34085/en/ProTOOLKITPlatformsWildfire30.pdf. Hope this helps. Rameet
Hi.. Just a small mistake in the link.. http://www.ptc.com/WCMS/files/34085/en/ProTOOLKITPlatformsWildfire30.pdf Rameet
Hi, The platform support is available at: http://www.ptc.com/partners/hardware/current/support.htm You need to select the product using the drop doen menu in "By product" option. Rameet
