Hello!
I created a solid via the ProSolidMdlnameCreate function with type PRO_MDLFILE_PART.
The problem is I realized that the solid is well created but has not a coordinate system CSYS.
Do you know why? I think it is normal, I tried to create a solid via Creo template and there was no CSYS too.
And do you know how to create a CSYS in a solid with protoolkit C code? (I'm using Creo 7.0)
Thank you very much!
You need to use another function to retrieve template model. Then copy template model to create new one. In the template you can create csys or any features which you need. Prepare template manually before copying.
